1992 OLDMOBILE CUTLASS SUPREME SL
ENGINE Type: 60 degree transverse, 3.4 liter Twin DOHC MPFI V6 RPO Code: LQ1, VIN Code 'X' Displacement: 207 cu in, 3352 cc Valves: 24 valve, 2 intake/exhaust per cylinder Bore & Stroke: 3.622 (92 MM) x 3.3122 in (84 MM) Compression Ratio: 9.25:1 Firing Order: 1-2-3-4-5-6 Coil Connection Sequence: 1-4-6-3-2-5 Horsepower: 200 bhp @ 5000 RPM Torque: 210 ft/lbs @ 4500 RPM Yellowline: 6500 RPM Redline: 7000+ RPM Fuel Economy (city/highway) : 19/28 mpg
 SUSPENSION Front: independent, MacPherson struts located by lower control arm, tapered coil springs, 34mm anti-roll bar Rear: independent, tubular strut located by 1 trailing link and 2 lateral links, l4mm anti-roll bar
STEERING Type: power assisted, rack-and-pinion Turning Ratio: constant, 14.0:1
BRAKES Type: four wheel disc / NO ABS Front: 10.5 x 1.0in vented disc Rear: 10.1 x 0.5in solid disc Power assist: hydraulic
WHEELS AND TIRES Wheel size: 16.0 x 6.5 in Wheel style: 5 spoke straight star Wheel type: one piece cast aluminum Tires: Phantom HRX's (P225/60-R16 97H)
TIMES AND SPEED
0 - 60mph Time: 7.9 seconds
Quarter Mile: 17.391 @ 82.29mph
(my time: stock @ 5400 ft above sea level)
Top Speed: estimated around 123mph (limiter)
TRANSMISSION GM Name: Hydra-Matic 4T60-E Type: 4-Speed Automatic W/ Overdrive Chassis (motor / driveline): Front / 2WD Front Gear Ratio First: 2.921 Gear Ratio Second: 1.568 Gear Ratio Third: 1.000 Gear Ratio Fourth: 0.705 Gear Ratio Reverse: 2.385 |
EXTERIOR DIMENSIONS Wheelbase: 107.5 in Track (front/rear): 59.5 / 58.0 in Length: 194.8 in Width: 71.9 in Height: 53.3 in Ground Clearance (minimum): 5.9 in Curb Weight: 3396 - 3511 lb
INTERIOR DIMENTIONS Type: 5 passenger coupe / sedan Front Seats: sport cloth buckets, 6-way power driver seat Front Head Room: 37.8 in Front Leg Room: 42.3 in Front Shoulder Room: 57.3 in Front Hip Room: 52.0 in Back Seats: sport cloth benchseat with 3-point seatbelts Rear Head Room: 36.6 in Rear Leg Room: 34.8 in Rear Shoulder Room: 57.3 in Rear Hip Room: 53.3 in Trunk Cargo Space: 15.0 cu ft
CAPACITIES Engine Crankcase: 5.5 quarts with oil filter Transaxle (auto / manual): 9-12 pints / 2.25 quarts Cooling System (auto / manual): 12.7 quarts / 12.9 quarts Refrigerant (R-12), Air Conidtioning: 2.25 lbs Fuel Tank: 16.5 gallons |
